Engine Seems Louder (maybe knocking) in Low RPM Range
So, for the last few weeks my truck seems to be louder than normal.  Almost sounds like a knocking but only hear it in lower RPM limits (less 1200 rpm).  I don't know if its just me or not.  I don't have any CEL on or any codes that I can see with my Bluetooth OBD2 scanner.  I don't see any smoke and the truck runs good.  I did start getting diesel at a different station (Chevron instead of Fred Meyer).  Could it be a difference in diesel?  Could it be colder weather?  It does it with the Quad at 0, 2, 3 or up.  It does it with the daily tune and the performance tune.  I can really notice it at cruise with light throttle.  Any suggestions.  This is my first winter with the truck so as far as I know this could be normal. :shrug:
High cetane fuel could produce more knock than usual.
Each brand name carries its own additive package before being delivered to the fuel station. I typically stick to larger brand names Chevron, Shell, Maverik, etc.
Ok.  I will swap back to where I was originally getting fuel and see if it changes.
I wasn't sure if it was maybe a timing issue or something.
I did notice that my engine load toggles between 4 - 5 at idle according to my Quad and it seems to be idling high, usually around 920-ish so I think injectors are in my near future too.  165k on these ones.  The guy I got the truck from rebuilt the motor at 155k but used the same injectors :doh:
Here are the 2 tunes I've been using.
iQuad-Mopar1973man Performance-2019-03-15-08.27.04147447478196055003.json iQuad-daily-2019-03-15-08.26.444726115227942262255.json
Looking at these tunes in the tune builder they do look a little low on timing.  The daily one isn't as bad as the performance one (if I'm looking at it correctly).
