Napa map sensors and truck not running well
Are Napa map sensors any good? My truck has been thru 3 Napa map sensors in the last 4 months. I’m wondering if they’rs a deeper issue?
I have noticed lately that my truck is not running well and don’t sound at all like other 24 valves around. It idles rougher and overall sounds way different. Valve lash is good fuel pressure is good. I have a set of stock injectors I’m putting in soon and I may replumb the entire fuel system as I’m wondering about air in fuel. What you guys think? I’m getting very fed up with how it runs.
15 hours ago, Marcus2000monster said:
My injectors have 15k miles.
My First set of DAP 7 x 0.0085 SAC @ 305 bar where very rough running and stalled quite a bit. Injector issues typically. Again MAP sensor has zero impact on idle and low speeds. A rough running engine is usually because the injectors are not spraying clean or nozzle issues or possibly crossover tube issues. I had barely 8k miles on those injectors and had to send them back. Bad injectors can happen at low mileage.
I really hope this is the issue. And to clarify im not saying the map sensor is cuasing my idle and rough running issues. The map sensor issues are two different things I just put them both in one thread. Are map sensors from Napa ok qaulity or not? Like I said I have been thru three of them lately. Not sure if they're is a deeper issue...?
