Spit/sputter misfire? Defueling?
36 minutes ago, Dieselfuture said:
Well I know the whole key thing on VP, what if someone rotated the actual gear 180 or is just a toof or two off.
Edit
I suppose it could be a broken tone ring on the crankshaft, idk just brainstorming
When removing my pump the first time every thing I read about doing said the gear can't come out of position with the pump off. I tend to believe aftermseeing insidemthe gear case. Bur every once in a while someone would say it can move. Not sure I want see if it can just test the theory. I agree that it sounds like a timing issue but there is only one way I know to check the gear.
