  • Welcome To Mopar1973Man.Com
    We can see that your guest and been lurking about. When you register on the Mopar1973Man.Com site you'll be able to interact with all the other members. This is the most friendliest Cummins forum you'll ever join. Take the time right now and  REGISTER  on the Mopar1973Man.Com this will open up many more options and functions on the website. Everyone is very friendly and helpful just ask questions and everyone will help you out the best they can.
Sign in to follow this
AH64ID
Classified Ad - 245/70R19.5 LRG 14ply Toyo M608z on Vision Type 81A Wheels
Selling my 245/70R19.5 Load Range G 14ply Toyo M608z on Vision Type 81A Wheels.
This is the setup for hauling heavy on your SRW pickup!
5 wheels and tires.
14 ply tires rated for 4540lbs @ 110 psi
Tires range from 5-8/32nds remaining. Sidewalls are in great shape, and have always been stored under cover when not it use. Truck normally was parked under cover as well, no UV damage.
All 5 tires are balanced with counteract balance beads, perfectly balanced at any speed.
Wheels are Vision Type 81A Matte Black 19.5x7.50 rated for 4500 lbs. Bolt pattern in 8x6.5". 0 backspacking
Tires can be re-grooved to save money on tires when the tread wears out.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
