01 cummins not getting fuel to injectors 1 and 3
I just replaced the injection pump, the fass lift pump is working good, the pump is getting plenty of fuel. But I cant get it to run, it will start with ether but wont stay running. I have primed the pump and bled the filter housing getting the air out. Please help If you can
Edited by JP24valve
I had that problem. The issue turned out to be a bad 'new ' injection pump right out of the box.
Was a very frustrating and trouble filled time but having spent a week trying everything suggested here and way more had to get another 'new' injection pump and it fired up and ran fine.
Good luck !
