Wired a relay in that cuts power to the LP in start position.  Went to to the store this evening seems to be starting good now,  will know for sure Monday after towing the RV this weekend.  Thanks moparman1973 for the tip, sure better than another VP.
I did that with the last IP I had because of hard hot starts. Worked for a while. I used 2 relays in line to power the LP. 1 triggered off the ECM and 1 triggered off the power window fuse. That way the ECM is still in control, but power is cut 100% when cranking. Remember if the pump is wired to a key on hot and you're in a wreck the pump will keep running pumping fuel on the fire if there is one. Just something to think about.
This is so you don't have to wire anything in, just replace the relay with this one. As long as you have an aftermarket harness that comes with Fass or airdog, otherwise you'll have to wire in a relay base a factory setup.
https://m.delcity.net/store/Time-Delay-Relays/p_804415.h_804416.r_IF3003?mkwid=8TgfXoca&crid=11472933143&msclkid=244a8de769fc10e0a1ddd14a10340b58&utm_source=bing&utm_medium=cpc&utm_campaign=Shopping - PLA's(BSC)&utm_term=1100315444392&utm_content=Ad group %231
Edit
I'm just reading the instructions on this relay and it's working opposite from what we need, it keeps things powered on after the ignition is off not the other way around.
Maybe there is another one that does the opposite:think:  @IBMobile
Edited by Dieselfuture
47 minutes ago, kzimmer said:
That's a neat idea. Need an on-delay relay instead of an off-delay relay. Except then your key-on prime will get shortened, or cancelled.
Yeah but I don't think it will be a huge deal, mechanical pumps don't prime ether. The only other thing is if it's cold and you have to wait for wts to go out. And the initial key on sends juice to relay and if it's when it triggers it then not sure if it will work ether. Beyond my thinking.
What do you mean "worked for awhile"?
56 minutes ago, Mopar1973Man said:
Why not just measure the fuel pressure and adjust it to so in not exceeding 12 PSI at cranking. Pretty simple eh?
Keep it simple.  Doing an adjustment is a lot easier than doing a lot of rewiring.
If that doesn't work you might try this.
Thanks @IBMobile, I've been looking for a wire that's switched with engine running. I'm going to use it to disable the grid heaters through a 200 amp solenoid I got off of Amazon while the engine is running. I think it's the simplest way to protect the alternator from the grids. Sorry to get the thread off topic.
