Truck randomly dies HELP!
I’m not sure where or what to look for or at I’ve made sure the injection does not have air in it, I tried to make a little jumper to bypass the fuel system relay and it popped a fuse and when I did make the right connection the truck still died but when I jump two particular ports on that relay I can hear the injection pump make clicking type sounds idk if that means the pump is bad or the brain on the pump is bad any of y’all have any more input
