Hard start in morning, then good rest of day
Yes I get that. Just thinking if dirty/bad connection, would cause truck to turn over slower, make it harder to start in the AM with a cold engine. One way to check would I guess to plug it in and see if that changes anything as well. If it pops right off plugged in then maybe she ain't getting enough juice to turn over sufficiently in the cooler mornings
Typically causes are starter contacts and the brushes are worn out in the starter. Being the starter contacts bridge when the solenoid pulls it closed and supplies the power to the starter motor. A common issue and cheap to fix. The brushes do eventually wear down and typically one brush will be too short to make contact and the starter now rolls at 1/2 power and speed.
I have had hard start issues a couple times.  Just recently it was after I changed injectors.  I figured I had a leaking injector feed tube.  Checked and re-torqued to no avail.  It turned out to be a leaking supply line washer, this did not leak fuel just let air in.  Changed all 4 that led up to the VP and no more problems.  With that said mine would fire right off then die/ sputter.  That is what eventually led me to the supply side of things.  I have also had the intake heater corrode and fail.  That led to slow starting as well but also to poor running until things got warmed up a little (maybe 30 sec) .  Maybe a little more info on how it runs/starts would be helpful in chasing down weather its electrical or fuel related.  I know these trucks start way better with good batteries especially in cold weather.
It will or has been until this morning crank for 10 seconds or so then pop off. Idle will be perfect, no sputter no quitting. In the winter plugged in it would pop off no problem. Once imafyer the initial morning start its smooth sailing rest of day. Shut the truck off for a few hours and it will still start right now. It's just over night. Until like I said earlier I cleaned up the batteries and all connections last night and left the fuel cap open a hair, and this morning it fired right up maybe 1.5 revolutions as per usual. Was +2, +3 celcius when I started it. So that's why I'm almost wondering if it is battery related or a clogged tank vent because something changed
I think you are on the right path.  Does your amp meter fluctuate indicating the grid heater is working?  Like everyone said good batteries and clean connections make a huge difference.  How old are your current batteries? Might be worth getting them load checked.
What is your fuel pressure during the morning start? Does it drop out and rise? That is an air bubble. Tank vent is possible being as the fuel cools it will create a natural vacuum if the tank vent is plugged up.
Just thinking out loud here but wouldn't there have to be a leak in the fuel system for the vacuum to pull the fuel back out of the system? Cooling fuel can definitely create substantial vacuum just look at a 5 gal gas can.  Either way it should be easy to check with shop vac or an air compressor.
I haven't watched the pressure when cranking...but when I've bumped the starter it goes from 0 to 22ish like right now
Yes batteries fluctuate as per standard procedure. And they are 3 years old which makes me wonder. I did load test them yesterday and they did check out. They were in the green, and yes I checked them individually. I also tested while charging and that also checked out
I've had issues with 3rd and 4th gens over the years and batteries, where they get a bit weak and everything is a downhill slide so it makes me wonder again. They load tested but just passed
Thanks for all the replies fellas. I appreciate the ideas your coming in with. This is a great forum. Thanks!!
23 hours ago, Liviniuk said:
...... Ya. The banjo on the back of the head was cleaned and installed with new washers and tee has been checked. I could always change the push on o ring for what its worth.
I think you are stating you still use one of the original push on or quick connects in the system?
If you do, slap some wheel bearing grease on there, and see if you problem disappears for a few days......
If it does there is your issue.
my truck insta starts if it has not drained back.  It takes between 7 and 10 seconds of constant cranking when it does drain back.
HTH
Hag
  • 2 months later...
2 months later...problem solved...
Believe it or not...the only damn hose I did not check or even thought of was the fuel pressure gauge hose....it rubbed a pin hole leak from vibration....finally rubbed enough to see fuel pissing out of it. Was in a really crappy spot that was not accessible to the eye. The old 01 fires like a top again!!!!
Might want to follow my write up no issues...
Even @mr.obvious has built a setup similar and I'll have to get photos and post up later.
So...after 4 months of putting up with the hard start...I canned the junk lift pump again and went fass titanium. Then I popped the valve cover retorqued all the injectors, also injection lines. Damn thing starts half a crank. Why didnt I do this 6 months ago :( thought I'd post and help someone else out. I did get half a turn maybe a bit more out of the 8mm injector hold down bolts and injector nuts. Who knows. It's been rock solid for a week now so, here's to hoping!
