How long do you have to keep the batteries disconnected  to drain the computer, in order to reboot?
  I need it to be rebooted so that it will shift out of 1st gear (automatic trans) without removing the relay & manually shifting only giving me 2nd, & 3rd gears.
Edited by Rayce
Spelling glitch
Draining all the power out of the system is as simple as removing ALL 4 battery main wires from the battery terminals BEFORE touching the negative and positive main wires together on each side.  It will complete a circuit without the batteries in the loop and use up the rest of the power in the system.  DO NOT do one at a time or you will fry some stuff and have 2 problems on your hands.
With that said I agree with the previous posters...sounds like you have a transmission problem that draining your system of electricity will not help.
