Apps voltages!
I still have my TC lock up issue so this morning I thought I would check my apps voltages.
0.314 at idle climbs perfectly but max voltage is 3.46 at 100% throttle I believe this is too low?? The quad is showing 100% throttle.
Any input would be greatly appreciated guys
11 hours ago, Mopar1973Man said:
Timbo's or what type of APPS?
Your starting voltage sounds good. Top I'm going to guess is OK. I would do a APPS relearn process. This will reset the voltage limits from idle to WOT.
Thanks already tried the reset and it has the original apps. Back to looking at other possibilities
