DAP used to rent one by the month and I thought people were doing that very thing with them. Thought that was about the only thing you could change that would stay after returning said truck to srock. The 6 cylinder high idle kicks somewhere around 32* and the 3 cylinder somewhere between 32 and 0. But there are other parameters that have to be met also which I dont remeber.
To enable high idle: use a Smarty one time and it automatically enables or go to the dealer and have then enable high idle using the DRBIII tool.
6 Cylinder high idle is enabled at 32*F IAT with grid heater running.
3 Cylinder high idle is enabled at 15*F IAT with grid heater running.
I will probably rent on from DAP if i can't find anyone local. Wanted to get it turned on so I can install the mopar1973man idle switch. Just figured I'd see if anyone here was local and wanted to make a few $$.
I don't trust the dealers around here. I tried to get a few of them to do a flash on our Grand Caravan. Had service bulletin in my hand. 2 dealers flat out refused to do it. 3rd had me talk to their "best drivability tech". After talking to him i gave up. I really need to find someone with access to a DRB111 that knows what they are doing with it.
