Even my hy35 I've seen 35psi pur ov pulling grades.
If I get on it it pegs 30easy on flat ground.
Though even getting high psi numbers I think I'd make more power run cooler and smoke less with a hx40 youd truck might benefit to hx40 can be had for 300 bucks. Youl need a down pipe to use it. It has 4" outlet where the hy/hx 35 have a 3"
I have my waste gate turb buckled closed doing gor me almost 10psi and it runs cooler pulling grades
