Need Quadzilla adrenaline tuning help
Jerm2554
I recently bought a Quadzilla Adrenaline 4k v2 programmer and am having some tuning issues I cant seem to figure out. I only use the truck for sled pulling and do not drive it on the road. The main issue I'm having is at the end of the pull it will stay revved up after i let off the pedal for a short time and then come down to an idle. Any help would greatly be appreciated!!
Power level:9
RPM LIMIT:4000
VALET MODE:25%
MAX FUEL STRETCH :5800
TPS MAX: 75%
TPS MIN: 15%
MIn. Pump tap fueling: 10%
Pump low boost scale: 5 psi
Boost scaling: 20 psi
Fuel load timing: 0°
Low psi timing reduct: 3°
Timing reduct scaling: 100%
Light throttle timing adv: 0°
Light throttle limit: 0°
1500RPM: 16°
2000RPM: 19°
2500RPM: 21°
3000RPM: 23°
3500RPM: 25°
4000RPM: 26°
MAX: 27°
0PSI:110
1PSI:111
2PSI:112
3PSI:113
4PSI:114
5PSI:115
6PSI:116
7PSI:117
8PSI:118
9PSI:119
10PSI:120
11PSI:122
12PSI:123
13PSI:125
14PSI:128
15PSI:131
16PSI:134
18PSI:137
20PSI:140
22PSI:142
24PSI:144
26PSI:146
28PSI:148
30+PSI:150
This is the last tune I have ran.
First thing I see is your timing is really low
try
1500RPM: 16°
2000RPM: 19°
2500RPM: 25°
3000RPM: 29°
3500RPM: 32°
4000RPM: 32
MAX: 32°
Turn stretch down to 5000 and try again
TPS max to %100
boost scaling 40
Ok sounds good, i had a feeling timing was on the low side!.
I will give it a try tomorrow evening and let you know how I make out! Thanks for the help!
The quadzilla will only allow me to go to 30° not 32°
Are you at %100 throttle?  How about boost?  Rpms?
Many things play into how much wiretap.  As you noticed too much wiretap can cause issues.
Are you unhappy with somethinng other than seeing %90 rather than %100?  Just because you are only running 90% doesnt really mean you are lacking anything.
One could say since you are only using 5000 for fuel stretch you are only using %75 wiretap.....
Edited by Me78569
