  • Welcome To Mopar1973Man.Com
    We can see that your guest and been lurking about. When you register on the Mopar1973Man.Com site you'll be able to interact with all the other members. This is the most friendliest Cummins forum you'll ever join. Take the time right now and  REGISTER  on the Mopar1973Man.Com this will open up many more options and functions on the website. Everyone is very friendly and helpful just ask questions and everyone will help you out the best they can.
Sign in to follow this
Bojon
Bucking at low RPM's
I'm having an issue with my Quad when I'm lugging the engine.  So just to be clear when I say I'm lugging the engine I'm not talking about low RPM high throttle,  I mean very light throttle while navigating traffic.
At any rate,  when the engine is around 1200 RPM's I'm having an issue where the Quad is advancing timing to the point of bucking.
I've been able to verify this issue in my driveway,  switching between lvl 0 and lvl 2 I can watch the timing jump roughly 2°. I thought the Quad didn't alter timing until 1500 RPM?
Share this post
Link to post
Between 1000 and 1500 only the timing slider is considered. Light throttle and load timing are not used.
Drop your 1500 timing by 2*
Share this post
Link to post
Can I damage anything setting t too low? I've already dropped it to 12°
Share this post
Link to post
The export button is currently crashing the app for me. I'll paste it the hard way when I'm sitting in front of a computer later.
Share this post
Link to post
The App was updated July 23.
I'm fairly certain the Quad is up to date. If I'm showing a build date on the app does that still mean it's the most current?
My phone (Galaxy S8) updated a few days ago. The export was working correctly last I tried,  around a month ago.
Share this post
Link to post
Tried exporting some logs, but that feature is crashing my app as well
Share this post
Link to post
Uninstall your app completely and reinstall.
I think some data is getting mixed up and causing all sorts of issues.
Share this post
Link to post
In a nutshell.
"Max Timing" sets the maximum limit of advancement, excluding cruise timing which stacks on top of this. Now the rest of the setting like load based timing and low psi timing reduct are all amounts of retarding from the Max Timing number.
The other clue is oil temperature oil should be roughly -10°F cooler than coolant temperature. If oil temperature is above coolant your too advanced and burning too much fuel on the cylinder wall and not in the bowl of the piston. If the oil temperature is colder than -10°F then you most likely retarded too deeply burn most of the fuel on the downward stoke and blowing most of the fire out the exhaust. This is not exact science but a good way to find timing range.
Share this post
Link to post
Just to follow up on this, after unplugging my Quad to send in, my bucking issue has stopped.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
