Looses prime
Air leaks. Typically occur on the suction side where there is no pressure but vacuum that draws air in. What happens is you park the truck it continues to draw air into till the system has lost prime.
Get it running as soon as you shut down pressurized the fuel tank using blow gun and a rag. Now have a second person hunt for moist joint with the system pressurized.
Only need 1 to 2 PSI. Don't get crazy with pressure.
