Just for fun...
boost correlation with HP would be hard to measure, (variables like turbine size, compressor wheel and turbine wheel size, gated housing or non gated, altitude etc.)
hx35 might fit rule of thumb of 8-10HP per psi, but drive pressure and altitude would still affect it considerably.
HX35 would be LUCKY to get much more than 54lbs/minute at likely 60% efficiency at 35psi
62mm sxe @ 30 psi could flow up to 75lbs/minute or nearly 60psi at 76% efficiency
Edited by dieselautopower
