P1697, P1694 and P1698 no bus codes
P1697, P1694 and P1698 no bus codes. No gauges working, most dash lights on, truck is running fine. 01 Dodge Cummins 5.9 turbo with Edge Juice chip installed a year ago...any suggestions where to start??? I can't afford a ton at a mechanic.
There is no 1697 that I see verify your codes again
1698
1694
1687 ( guessing)
I'd start by putting the truck back to stock and see if the issue goes away.  Typically bus errors are related to a short in the ccd wiring or something on the bus that has failed.
Edited by Me78569
