New lift pump. 95 vs 165
12 hours ago, Gregturley said:
Mechanical pump will probably be more reliable than any electric pump. Flow and pressure also increase with RPM. Most electric pumps will lose a little pressure at higher RPM's.
This is the way I went.  I failed to see the logic in replacing an electric pump with another electric pump.  Kinda like kicking the can down the road...or doing the same thing twice and expecting a different result. :kick:
I figured if I'm gonna gamble with a grand (cost of new VP44), I'd just hit Vegas instead and get similar odds while having a much better time.  There just aren't as many showgirls around when I'm working on the truck. :cheerleader:
