330IT Mom wagon project
Me78569
Today I spent a few minutes fixing hte clear out on a small area.   I also got some trim pieces installed that were missing.   color isn't %100 but it is close enough.
Big fix was there is a "DISA" valve in the intake which simulates longer intake runners up top in the rpm band and shorter runners down low by opening and closing.
there is a Oring on the valve that the PO thought to use some RTV on, rather than by the $5 oring and replace it.  The vacuum leak was causing some O2 codes and rough idle and elevated idle while on the brakes.
Went down to ACE, spent $0.65 and got a new oring and fixed it up.
On my vw there is a what's called swirl flaps, it's a spacer that goes the length of the plenum. Designd to push more air in at lower rpms I think. They avantualy wear out and brake, causing some pieces to go in engine and damage. Not sure if yours same or similar. I had mine disabled in full open position. You can buy a spacer kit I believe to eliminate it.
  • 3 weeks later...
Replaced the steering coupler this today.  I can say that the old one was really bad resulting in the car jumping around on different surfaces and shimming on deceleration.
I am kinda thinking the front end was fine, but oh well.
open-uri20141107-2865-jpnzhx.?1496445351
  • 3 weeks later...
  • 1 year later...
Made some progress and ordered some parts.  I can get it back on the road for ~500 and looking back to normal for ~1000.
Got everything broken pulled off and banged out the mounting and wheel well.
