Boost readings off OBDLink
2 hours ago, Remington92 said:
Maybe Im being stubborn but id like to avoid putting in analog pillar gauges. I much prefer the clean look of having everything on one small screen.Do the quadzilla or edge insight/ juice guages read correctly?
I get it. My fuel pressure is on the A pillar still. Going to move it one day. There other options and I like this better.
8 minutes ago, Tractorman said:
Well, no wonder you blew the intake manifold gasket!!  :lol:
- John
But i can only to 34 at WOT. But let clutch out and you're  doing 40 before it's  fully engaged. 4th gear launch required.
14 minutes ago, Dieselfuture said:
I want to see my gauges up close so I don't miss anything post-1102-0-85369600-1422214642_thumb.jpgpost-1102-0-60175500-1422214663_thumb.jpg
old pictures but still same.
2 reason I did not do mine that way. The main was I had just installed the new dash pad and could not make myself drill a hole in it. The second was i got usdd to it at the windsheild and can see it just fine. But I like yours too.
