throttle position reading
OK guys looking to what you guys have for throttle position percentage reading at 70 MPH cruise with 3:55 gears and 47RE trans thinking mine is a little high from what I can remember but I could be wrong mine is at like 24-25% at 70MPH cruise I thought was usually around 17% before just can not remember??? Thanks in advance reading from quadzilla adrenaline
Edited by 24vcumminspower
Fair enough. Next time I hit the highway I'll try to remember to have a look.
Edit: Next Post
Have you changed anything on your tune lately? For example, a drop in the canbus fuel percentage settings at the boost PSI range you cruise in would force you to use more throttle to get the same amount of fuel.
Edited by kzimmer
Clarification
