2001 2500 5 speed trans fluid
Valvoline MTF is good.
Mobil 50 SAE is good.
PenzOil Syncromech is good.
I've used Mobil 50 SAE in my truck no issues. Over powered 5th gear and ate the teeth off the gear. I've done several services on customer trucks and used both PenzOil and Valvoline both and no issues at all for the NV4500
No need for Redline and AMSOil fluids. There is a wide field of fluids that work in our trucks. GL-4 is the only requirement. Viscosity wise even the Dodge dealer will fill with ATF+4. Personally is too thin.
Gotta remember I work on several truck and give options to my customers on what they want to use. I stay and touch and so far no issues.
hey, thanks for info. it is surprisingly hard to get a answer from any parts place on what to use.2 dealerships i do business with both said atf-4, could not bring myself to go that way.  thanks for the help,   ed
