Reverse trigger wire
Installed a new radio head unit. The factory tailgate camera is working by manual selecting camera on unit. But the reverse is not triggering the camera. After further research i need to tap into a reverse trigger wire at the bcm but unable to locate the correct wire. Thanks
2015 ram 2500. Yes on canbus interface. I have seen where people have said if you tap into the reverse wire of the taillights that the interface sends false signal that bulb is out. They have tapped into the reverse wire of the 7-way plug. But these are all situations where someone is looking for a reverse trigger wire at the back of truck not inside the cab.
