Starts fine, runs strong, then stalls. restart only after fuel overflow valve reset
I don't think your troubles are like the time I had fluctuations in fuel pressure after going thru everything. Could not figure out what it was I had been thru both trucks fuel systems completely i.e.  new Raptor pumps,draw straws, big line kits, removed tank basket screens, everything. Trucks didn't shut down, but 2-4 bounce with the fuel pressure. Then Mopar Man had me run the regulators pressure adjustment up and down a few times with the trucks running. That stopped the problem.
Another Thought.... I've only heard of the tank vent cogging 4 times since reading the forums.... you might try running with the fuel cap loose see if the works. Just a maybe is all
Edited by JAG1
