Sucks on the highway
My 1999 24 valve at highways speeds seems to have no throttle response. Up hills truck can drop a bit below speed and when I give fuel nothing .. hit flat ground and away it goes ..
truck pulls and shifts flawlessly at non highway speeds .. 23lbs boost, no lower then 10psi fuel, any ideas? It’s embarrassingly be able to be put pulled by a gasser you hill on the highway
Check engine light not on
  • 3 weeks later...
