Should i buy a 2nd hx35?
19 hours ago, Gregturley said:
Somethings got to give. I'm done spending money for awhile. I'll research this turbo thing and have another project for the future. I'm going to put the 1st hx i ordered on when the rain stops and leave it be for awhile.
 FYI my HX35 went 853K before I rebuilt it. Now has 42K so it's proved itself. 50K is nothing.
Edited by Blueox01
25 minutes ago, Gregturley said:
50k is pretty low if thats what it really is. I'm wanting to replace my hy35 and have many carefree miles. The 2nd one was cheap enough i figured might as well get it and learn something.
Rebuilding a Turbo isn't  hard
I was more referring to aftermarket wheels and find out more info about hx35 upgrades
Not always a good idea unless you get right wheel and housing and you can only go so big without changing the exhaust impeller. Not sure if it's worth the hassle unless parts are cheap or like you said Mike got one used from member and rebuilt it for $50 DAP sells holset kits.
The turbo in need of a rebuild showed up today. Has a little more than "some" shaft play. Looks like the compressor wheel has some damage, can't tell about the hot side haven't got it apart yet. That might happen later in the week. So much for a $50 kit.
50k turbo supposed to be here Friday. Hope its as advertised.
