01 dies in gear but idles fine
Did it just start happening, or a gradual occurrence?  anything recently changed in your truck set up?
Sometimes bigger injectors or injectors at higher pressure combined with a tight converter will cause stall when put in drive.
Also make sure your truck is warmed up prior to putting it in drive.
