  • Welcome To Mopar1973Man.Com
    We can see that your guest and been lurking about. When you register on the Mopar1973Man.Com site you'll be able to interact with all the other members. This is the most friendliest Cummins forum you'll ever join. Take the time right now and  REGISTER  on the Mopar1973Man.Com this will open up many more options and functions on the website. Everyone is very friendly and helpful just ask questions and everyone will help you out the best they can.
Hello gentlemen I have a 1998.5 cummins with an auto. I have recently done the vp44,(stock), injectors(85 hp), apps sensor, and overflow valve(stock). So the issue I’m having is that when the truck is cold or upon first start up letting it run for a few minutes then I put it in drive or reverse it either dies or wants to die. I’ve never had this issue before I did everything listed above. The apps sensor is set to .55 volts at idle as specified. Did the bucket test for my fass 150 everything is working fine and is running 17 psi. Just curious what you guys might think it could be? When the truck warms up I have zero issues. I was thinking torque converter but this one is fairly new and it has not done it Before. Any input would be appreciated
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
