Mopar1973Man Economy Tune
  • Administrator
View File
This tune is rock solid above 20 MPG for sure. It is repeatable. The first test trip was from Riggins, ID where I filled and the to Donnelly, ID then to Lewiston, ID. I netted 28.04 MPG. This last trip I've gone 425 miles on just a half tank of fuel.
REQUIREMENTS:
You must have a final ratio to the ground close to 3.73 gears. I'm 3.69:1 ratio with the 245/75 R16 tires (30.5 inches) I'm running. Injectors are +150 HP DAP VCO Injectors popped at 320 bar. I'm running a slightly bigger turbo HX35/40 hybrid. Drive to speed limt but no rocket launching from stops. Take your time building speed up.
425 miles on just a half tank of fuel. Not many can do this...
Hand math on the first test run.
  • Submitter
  • Submitted
    09/11/2021
  • Category
  • Injectors
    150 HP VCO DAP Injectors popped at 320 bar
  • Turbo(s)
    HX35/40 hybrid (60/60/12)
  • VP44 wiretapped?
    Yes
  • Injection Pump
    Stock SO
  • 11 months later...
How would this tune run at sea level?  I live in the California valley and my home is at 68 feet of elevation.  I will  up to occasionally be above 5000 feet.   Would you recommend any changes for the lower elevation?
Thabks,
Brian
  • Current Donation Goals
    • Raised $101.00
