Boost Level with Quad
  • 3 weeks later...
You can just plug the hole in the turbo housing where hose comes out to the waste gate actuator to see if it makes a difference. I had plug in mine 1/8npt for years now. With the set up I'm using I haven't had an issue. Just checked my drive pressure against boost and it's 1:1 all the way to 48 psi with wire tap on. I think the waste gate is being pushed open by drive pressure around 45. On level 3 canbus only I can get close to 40 psi.
