2nd hand vehicles, you might want to check fuses
Like I'm learning you might want to get a hold of the Dodge FSM and then look up all the ports used in the fuse panel and what size fuse goes where. I found a few with a larger fuse stuffed in the port. A few I found where missing a fuses completely which explains why some thing never worked right. Like I did with Thor I got the 2006 Fuse list and ran right down the list and made sure each port had a fuse that was hook up and tested good. Then I found the fuse I was chasing anyways for the tail lights. Next step would to be re-test against my RV when the snow stops again.
