Lifter Inspection Cover Leak
NAPA gasket is all I ever used.
Now make sure your cover isn't warped and that there is no issues. Do NOT use silicone on the cover or gasket. I just slip the new gasket on making sure that its facing the right direction typically there is a tab showing direction. Then tighten the bolts as usual and reassmeble the VP44 into the gear case.
