Scan pulling up Mercedes info
My simple scanner does that too. When there is a companion module fault the scanner needs to be told what to expect so I have to manually select chrysler then it works ok.
I suspect it's because the ISO9141 Protocol which is k-line and L-Line bidirectional comm. The protocol supports multiple ECUs/PCMs on a shared comm bus. The k-line was popular on many European cars at that time.
OBDII and computers on cars were not well standardized at that time and many manufacturers winged it.  So there is a lot of unsupported features.
