Double cardan joint grease
13 hours ago, Lund1990 said:
had the shaft rebuilt at fleet pride a few years ago.  I would have thought they'd put a greaseable 1 in but I guess not.
I assume you talking about the driveshaft from the transfer case to the front axle.  Has that driveshaft failed in some way?  If not, I recommend re-installing the driveshaft and don't worry about it.
Two weeks ago I pulled my non-serviceable front drive shaft for inspection.  All joints were working smoothly.  I re-installed it.  It has logged over 380,000 miles.
I used to be a believer that non-serviceable u-joints had shorter life spans, and maybe they did 30 years ago.  Since then, I have learned that there is a lot more that goes into an OEM non-serviceable u-joint - mainly the triple lip seals that keep the grease in, and the dirt and moisture out.
- John
Edited by Tractorman
I'm able to grease all 3 u joints in the shaft just not the ball and socket. With the salt like, Mopar1973man mentioned, it eats up joints. Plus with the hell I put this truck thru occasionally, just think it makes more sense to be able to grease it. Now on my 2004 I wouldn't be as concerned because that basically just my camper/Trailer hauler.
