  • Welcome To Mopar1973Man.Com
    We can see that your guest and been lurking about. When you register on the Mopar1973Man.Com site you'll be able to interact with all the other members. This is the most friendliest Cummins forum you'll ever join. Take the time right now and  REGISTER  on the Mopar1973Man.Com this will open up many more options and functions on the website. Everyone is very friendly and helpful just ask questions and everyone will help you out the best they can.
Sign in to follow this
jamescraig
The problem of long path files and tools to solve it
I want to share with all those who are victim of such long path files Long path files are those files which have a path having charcters more than the limit allowed by windows,ie approx 200 Whenever we want to change,delete,move,cut,omit,share or install such file windows give error like file is copy write protected,it is used by some other application or user,is blocked etc First way is to change file name but it dont work Second way is to delete such file by holding shift but it also dont work Third way is to use a tool which embeds into core and resolves such long path,there are many tools available both freeware and shareware,here are some with their destination websites: 1.First of all is robocopy which is a tool given by microsoft for copying and xcopying files using command line interface,this robust tool boostes copy procedure but is leaste effective for long path files,i will rate it 1 star 2.Second one is pathlongtool available at pathlong.com,it is rated 2 star because it has limited functionality in case of mapping and changing such files 3.Third one is Long path support Api,this is a complex tool for advanced users having complex accessibilities,i will rate it as 2 star,it is avilable at file32.com 4.Fourth tool is bitchip file gear,it is a file copy gearer which cannot map and delete long path files but is extremely useful in gearing copying of such files,rated as 3 star.It is available at file32.com 5.The most effective and efficient is longpathtool availabe at http://www.longpathtool.com ,it is a small,smart and quick to use software which can be easily downloaded from its site,it has optimum functionality and it can change,search,map from network,omit,copy,install and delete such long path file effectively being rated as 5 star
Share this post
Link to post
  • Donation Goals
    Mopar1973Man Medical Bills
    If you want to donate to Michael Nelson medical bills. Any fund donated here will be directed toward the medical bills and getting them paid.
    10%
    $50.00 of $500.00 Donate Now
