  • Welcome To Mopar1973Man.Com
    We can see that your guest and been lurking about. When you register on the Mopar1973Man.Com site you'll be able to interact with all the other members. This is the most friendliest Cummins forum you'll ever join. Take the time right now and  REGISTER  on the Mopar1973Man.Com this will open up many more options and functions on the website. Everyone is very friendly and helpful just ask questions and everyone will help you out the best they can.
Thank you for your time. Im a new member with which may be a stupid question. I own a 2001 2500 auto. A few months ago i shut my truck off and it never restarted. I had no fuel to the fuel filter housing. I had my lift pump replace with an intank unit, first mistake, second i had someone that in my opinion now wasnt able to do the the job. After that didnt work a new injection pump installed, no luck. A computer diagnostic ran, no luck. I have no codes but truck will turn over but still wont run. After towing the truck home, i discovered a short in the power door locks fuse which controls the ctm. My truck has the anti theft feature but didnt have any symptoms before the pump swaps. Would the ctm lock up be the problem or am i over thinking this? Thanks for any thoughts on this i appreciate it!
Share this post
Link to post
Yes... The CTM (Anti-thief) will prevent the engine from running I would look into fixing that and I think you'll find the truck will start...
Once again welcome to the site... As for stupid questions... There is no such thing as a stupid question here on the site... The only way you are going to learn is to ask questions.
Share this post
Link to post
Thanks alot i appreciate your time. You are the only one that has heard of this it seems, i was beginning to second guess common sense which is never good. Thank you again sir!
Share this post
Link to post
Welcome.You are among friends here. We are all here to learn. Agreed, that there is no such thing as a dumb question. What is unfortunate is a legitimate question not asked. Those that know the answers (and it's not always the same people each time) are pleased to share. As a group, we are stronger.Russ
Share this post
Link to post
I appreciate this guys, i asked the same question elsewhere and the answers i received were more off topic or 'let me guess' then a straight answer. Thanks again. btw since i did unfortuantly have an intank pump installed should i replace it immediatly change it or just add an auxiliary pump?
Share this post
Link to post
While replacing the pump is the best option an auxillary pump will work. I ran one for over 2 years withreasonable sucess. This was befor e I learned the inportance of fuel pressure. I had the in tank pump like you and started having some small problems, a little bucking and occasional dead pedal. Took it to a shop and they pointed out my fuel pressure being very low. I added a booster pump from BD Diesel and it got my pressure up to acceptable levels. Turns out it was a Carter fuel pump sold by BD diesel. At that time I still did not how improtant it was to monitor your pressure, so I did not install a gauge. To make a long story short, if you are tight on cash, add an auxillary pump if you want to, but make a fuel pressure gauge #1 on your list. the aux will work but you need to watch the fuel pressure an keep it at least over 10# untill you can afford to go the right way. Just bear in mind a booster pump has got to cost at least $250. you ought to look at Air Dog or FASS for a suitable replacement and piece of mind. It is more upfront, but at least you could go ahead and put it behind you. The intank pump is crap.
Share this post
Link to post
your answer is appreciated. I have around 500-600 left after new ctm. Is that sufficent for a proper upgrade or should i save a little bit more for a proven set up? thanks again
Share this post
Link to post
http://www.pureflowairdog.com/airdogII.php http://www.xtremediesel.com/pureflowairdogiiairfuelseparationsystemdf-100wadjustableregulatorquickconnect.aspx ^This oughtta get you in the right direction. Edumacate yourself about the fuel delivery system and the importance of it with a diesel engine. Then also understand this in relation to a vp44 injection pump. This system should be in your budget, and is the least I would go with. If you plan on getting crazy, front the money now instead of later and get a higher model one. I got my ADII 165gph for about $650. Look around for deals and I bet you can find one for about the same. If you go this route, with a 165, you will have to yank the tank and modify the basket in the tank to allow for better suction. For a diesel engine, the fuel is the blood, the life of the engine.
Share this post
Link to post
Installed new ctm this morning. Non of the fuses blew this time and everything worked fine but still no start and no security light. Any thoughts guys, id appreciate them. Thanks
Share this post
Link to post
Verify the Red/Green wire on the VP44 is getting power. Make sure the fuel pump relay in the PDC is good. If the injection pump is powering up of course it won't fire up. Geez I feel bad the money spent on a CTM and no dice... :rolleyes:
Share this post
Link to post
The new ctm was needed but i believed it cured half the problem. I am now getting grey smoke from the tail pipe while cranking when none was present bf. My pressure at the injector lines is good, just think im overlooking something simple.
Share this post
Link to post
I reprimed the injection pump and bleed the injection hard lines this morning. I got good flow and no air in all the lines but the number2. I repeated the 30 sec cycle on the number 2 line a few more times with no sucess. I stopped when my batteries got weak. I put then on charge and will go from here when they are fully charged. Could this be a vp problem or is it simply air locked somewhere in the number 2 hard line?
Share this post
Link to post
I dont know how you could do an individual injector line. I have heard several people say the lift pump will not pump thru the VP, but after I installed my AD, I bumped the starter with the injector lines(1,3,and4) loose and it did pump a fair amount of fuel thru them after a few trys. After hearing so many time the lift pump cant do that, I spent about 30 minutes looking for a fuel leak until I realized the fuel was coming thru the injector lines I had cracked open. I want to believe what I was told about that not being possible but I can still do it with mine. As far as pumping it thru 1 particular injector, I dont know. Mine was pumping it thru all of the ones that were open.Could this be possible due to newer upgrades in pump reman?
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
Sign in to follow this
  • Donation Goals
    Mopar1973Man Medical Bills
    If you want to donate to Michael Nelson medical bills. Any fund donated here will be directed toward the medical bills and getting them paid.
    10%
    $50.00 of $500.00 Donate Now
