Spring runoff...
How buried is the back of the house? could the water be entering through the foundation on that side, as opposed to through the floor?Unfortunately the only "proper" fix for that would be to expose that whole side of the foundation and waterproof the exteririor of it, and I'd still set up a french drain just below the slab level and then backfill with stone to help the water get down into the drain instead of sitting against the wall.Not an easy battle to fight. Things on the SIDE of a hill just plain aren't supposed to flood!Good luck in the battle.
