Inverter/Converter Location
I'm pretty sure my converter/inverter is bad. The only way to charge the batteries is to hook it to my truck or put a charger directly to the batteries. I have a 2005 Rage'n Xtra Lite and have no idea where it's located...or even what it looks like. Rage'n is out of business so there's no technical support. I'd like to find it so I can troubleshoot it. Any ideas?
My charger is built into the AC / DC panel in the kitchen. There are no controls / switches on it, comes on automatically with the "dockside" AC power. It's a metal box & mine has a hummmm. I would disconnect the AC from shore power & pull your fuse panel, see if anthing is unhooked. Mine was not a virgin (been F***ed with before) and I found things wired on the same breakers that would not hold set. Is your main breaker good? Do your other AC circuits work?
I believe all of the breakers are good and I've checked all the fuses in the fuse panel. Mine is a toy hauler and has a built-in generator. I would think it's somewhere around the generator. Now that I have a visual, I'll go out and take a look. Do they typically have any type of in-line fuses?
