Cummins Conduit bender.....
JAG1
Out on the farms I've worked on occasionally, we have needed some custom bends in our plastic PVC conduit. We found that about 10-12 slow turns of the pipe at the hot exhaust will not burn and make it soft enough to bend. Saves buying a 200 dollar conduit heat bender anyhow.Tip.... if you see the pvc turn color like it's burning, you need to turn it a bit faster :thumbup2:
