6.7 Engine problems
Hey fellas,I need some help, buddy of mine has 07 Dodge 2500 4x4. The engine is missing, has an egg smell coming from engine, engine temp is running warm, white smoke when cranks up, and steam look from exhaust.Any ideas would be a great help!!!Jason
Trying to find a mechanic around here that will help has been next to none!:banghead:So I decided to try and figure things out myself! Did a pressure test on the cooling system, and think I have it figured out! Pressurized the radiator to 15psi, and noticed that on the back passenger side of the egr cooler where it bolts on to the exhaust manifold, appears to be leaking. I ordered an egr delete kit, dpf delete kit, and a mini maxx programmer. I'm pretty confident that this is where all the problems are going to be. Will post pics soon, to see if y'all feel the same way!
Well got all the parts in Monday morning, started about 1030 putting everything on. Wasn't a bad job at all. Was completely done by 1. Having a lift sure made it nice to do the PDF delete! :D:D Took it for test drive, needless to say its back on the lift :banghead: I honestly don't know how he was driving this dang truck!!!! Was driving and this thing started wobbling violently :confused:. So I put it back on the rack and waiting for more parts to be in today! Tore down the right front side, both ball joints were sloppy, the hub assembly was toast, & the u-joint on the axle was bad! Anything else I need to look at?
