General Dodge Cummins HP/TQ by Model Year
Rogan
Nicely done. Don't forget the SO motor from 2003-2004250hp @ 2,900 460 ft/lbs @ 14002004 offered 2 HO's the 305 and 325 motors, the 325 was a Jan 04 release and didn't overlap with the 305 HO. Also there was a 5.9 offered in 2007, it had the same ratings as the 2006 5.9.
Nicely done. Don't forget the SO motor from 2003-2004 250hp @ 2,900 460 ft/lbs @ 1400 2004 offered 2 HO's the 305 and 325 motors, the 325 was a Jan 04 release and didn't overlap with the 305 HO. Also there was a 5.9 offered in 2007, it had the same ratings as the 2006 5.9.
Added :)
The torque management that's possible with electronic controls of engine and trans talking to each other is the key. You'll never see that 850 off the line, or while mid-shift. It's comparitively easy to make a trans last in top gear, higher RPM, full lockup with a ton of torque than while it's shifting or slipping.
