Introducing, Smarty Touch
Smarty Support
Introducing the Smarty Touch
The time is here. I would like to introduce to you, the Smarty Touch.
http://smartyresource.com/
Here is some information from Marco himself.
http://smartyresource.com/downloads/...SpecialDay.pdf
And some more valuable information for you:
http://madselectronics.com/SmartyTouch.html
And here is your Quick Guide:
http://madselectronics.com/downloadf...QuickGuide.pdf
Smarty Touch features:
•4,3" Touch Display. Resolution 480 x 272 - 16.3 million colors.
interface and the controller for communicating with the ECM.
•Fastest display start up in the industry. Just four seconds!
•Fastest PID refresh speed in the industry.
•Fastest ECM download in the industry, up to three times faster than the competition, a typical ECM update takes 1.5 to 6 minutes,
depending on the model year.
•Small micro USB cable connecting the display and the controller for easy installation.
•MicroSD card for simple and fast updates (included).
•Fully Internet updateable. Updates are always FREE!
•MicroSD card can store multiple UDC custom tunes.
•Works with any MicroSD FAT file system formatted card.
•EGT sensor (optional). Reads accurately up to over 2200°F.
•Four dashboards, each configurable with five different gauge layouts.
For details about the dashboard layouts please click here.
•Freely configurable gauge(s) range.
•Two alarms (high and a low range) can be configured for each PID.
•Audible and/or visible alarms can be configured.
•Configured ranges are also displayed through colored bars in all digital gauges.
•Configurable PID refresh speed.
•Each gauge stores/updates and displays the max reached PID value continously.
•Recorded max values can be reset at any time.
•Customizeable display background.
•Adjustable sound feedback for alarms.
•Supports over 300 SAE and Proprietary PID's.
For a detailed list of the supported PID's (depending on MY), please click here.
•Works on all Dodge Cummins Ram Pickup's from 1998.5 to present.
For details about the supported truck models please click here.
•CaTCHER software inside with ten power levels.
•Selectable performance parameters for fine tuning.
•Works with our UDC custom tuning software
•Can store any number of UDC custom files. The only limit is the storage space on the MicroSD card.
•ABS tire height updates in just seconds.
•Cold weather 3 Cylinder High Idle enabled for 1998.5 - 2002 VP 5.9L trucks.
•Not traceable in the stock setting. Smarty Touch leaves no footprint in all 5.9L trucks.
•Manual High Idle is enabled in all softwares for CR 5.9L trucks.
•Reads Diagnostic Trouble Codes in plain text.
•Clears DTC's.
•Reliable, it works off your OEM hardware.
•Programmable Speed Limiter from 25 to 250 mph.
•TNT-R and SSR software for CR 5.9L trucks (Requires unlock code).
•RPM and Shift limiters unlocked with TNT-R and SSR softwares.
•Power on Demand "PoD" for CR 5.9L and 2007 - 2009 6.7L trucks.
  • Like 3
