LED Lighting
Parts List
LED marker light
LED Taillight
Heavy duty LED flasher
As for installing it just simple change of parts. The flasher is found in your driver side of the dash. If the flasher been there a while then it might be difficult to remove. Just take your time and work the flasher it will come out. Pull the stock flasher out and plug in the new flasher. The replacement flasher can is slightly larger for the 12V dash. It will bare
