I decided to go through the trouble of installing a Momentary switch in the gear select arm. A Momentary switch means that it will only connect the circuit if the button is pressed. As soon as you release the button the circuit closes. IE: Pressing it will complete the Ground and trigger the Torque Converter to Lockup, as soon as you release the button the Torque converter lockup will release. This fixed the issue of forgetting that the switch was on when coming to a stop. I found th
