DTC P0217: DECREASED ENGINE PERFORMANCE DUE TO ENGINE OVERHEAT CONDITION
Monitor & Set Conditions
Decreased engine performance due to engine overheat condition is monitored with ignition on and engine running. DTC will set when coolant temperature signal indicates coolant temperature has exceeded the engine protection limit.
Possible Causes
ECT Sensor
