DTC P0252: FUEL VALVE SIGNAL MISSING Monitor & Set Conditions Fuel injection pump fuel valve circuit is monitored after current feedback monitoring is complete and average engine speed is greater than 700 RPM. DTC may be stored when Engine Control Module (ECM) does not receive a signal from the solenoid valve to indicate valve movement. Possible Causes Fuel Injection
