DTC P0253: FUEL INJECTION PUMP FUEL VALVE OPEN CIRCUIT
Monitor & Set Conditions
Fuel injection pump fuel valve open circuit is monitored when the ignition is on. DTC may be stored when Engine Control Module (ECM) senses engine speed is greater than 100 RPM and low current or no current is detected at fuel metering valve.
Possible Causes
Wiring Connector Problem
