DTC P0254: FUEL INJECTION PUMP FUEL VALVE CURRENT TOO HIGH 1. Turn ignition on with engine off. Using scan tool, check for DTCs. If DTC P0254: FUEL INJECTION PUMP FUEL VALVE CURRENT TOO HIGH does not exist, go to next step. If DTC P0254: FUEL INJECTION PUMP FUEL VALVE CURRENT TOO HIGH exists, replace fuel injection pump. Perform TEST VER-2A . 2. Turn ignition on with engine off. Using scan tool, clear DTCs. Start engine and a
