DTC P0382: INTAKE AIR HEATER RELAY #2 CONTROL CIRCUIT Monitor & Set Conditions Intake air heater relay No. 2 control circuit is monitored during the first second that ignition is turned on. DTC may be stored if Engine Control Module (ECM) does not sense that intake air heater relay turned on. Possible Causes DTC Equal To Freeze Frame Intake
