DTC P0460: FUEL LEVEL UNIT NO CHANGE OVER MILES Remove fuel tank. Remove fuel pump module from fuel tank. Fuel pump module is located on top of fuel tank and contains fuel level sensor along with fuel supply and return line fittings. Fuel pump module may also be referred to as fuel tank module. Inspect fuel tank for damage or obstructions which would cause problems with operation of fuel level sensor. If fuel tank is not damaged or obstructed, replace f
